Suggestion: High quality zoom only on fit
ZEUStiger
Post by ZEUStiger »
First of all, Thanks for the great program I've been using for many years. XnView is incredible.
Now to the subj:
Is it possible for "High quality zoom: [X] Fit" feature from an old XnView version to make a return in XnViewMP? Was there some architecture issue that led to the removal of that feature? It was useful for me when images were auto-fitted, and I generally use "Reduce only" now for this, but there's one problem - zooming out with really large images tend to be extremely slow, even in MP.
Re: Suggestion: High quality zoom only on fit
This option is removed in recent version of XnView :)
So you would like to have None/Reduce/Enlarge/Fit (and fit use high quality only if fit option is used??)
ZEUStiger
Post by ZEUStiger »
Yep, that will do.
But it would be even better to have something like this:
http://imageshack.us/photo/my-images/851/mockupa.png/
