XnView crashes on DB use.
Henry_Jones
Post by Henry_Jones »
XnView crashes repeadetly when accessing the XnView.db file. At least this is my conclusion after searching for the reason why it would work sometimes and sometimes not. If I delete XnView.db I can view a single picture with the setting - Fullscreen Viewer. I have a two monitor setting, so the picture is actually fullscreen on the second monitor and the browser is open on the first.
If I close the program and open it with another picture it silently crashes. No message is show.
If I change the Startmode to "Fullscreen Editor" I can view the picture (alas not on the second monitor) and close XnView without problems. But it crahes when I try to open the browser.
Everything works for one picture after deleting XnView.db. This file gets created even I have disabled the thumbnail cache.
The PC is in a domain and the settings (AppData/Roaming) are on a remote server (it is used directly without a drive letter). But even moving the DB to a local folder does not change the behavior.
On my home PC the problem is not present, but it's neither in a domain nor has it a second monitor.
What informations are neccessary to solve this problem ?
Re: XnView crashes on DB use.
Try to remove the xnview.db & xnview.db-journal
Henry_Jones
I did not found xnview.db-journal, but after deleting xnview.db again it works for now. :?
If it happens again, I'll be back ;)
