Suggestion - Import Image Listing
sergo
Post by sergo »
Hi dear authors of Xnview!
I have some suggestion, but may be it is already possible in XnView or XnViewMP.
I have a text file with list of image file full paths (just like Create Image Listing command produces) and I would like to process them in batch. Some of them I would like to delete and some of them to process in batch, but firstly I would like to make a review in thumbnails. Text file is a product of another program, so it will be very nice to have an ability to import this text file to XnView and to have this images in browser mode to review and delete or batch process them.
Is there some way to accomplish this task in XnView?
Thank you,
Sergo.
Re: Suggestion - Import Image Listing
In XnViewMP, you have 'open filelist'
sergo
Post by sergo »
It is just wonderful! Thank you Pierre!
BTW - command does not ignore empty lines - it just creates some empty folder-like thumbnails on empty lines.
sergo wrote:BTW - command does not ignore empty lines - it just creates some empty folder-like thumbnails on empty lines.
I can't reproduce, could you send me a file?
