Growing Image Size...
rchu2005
Post by rchu2005 »
I am new to NConvert so still trying to learn......
I have written a script to convert multi-page TIF into PDF while doing some masking but the resulting PDF/TIF becomes 200 times bigger than the original. Did I do something wrong? How can I keep the original setting of the image during a conversion?
Here are the steps taken:
- Convert the multi-page TIF (around 600k) into individual JPG files (around 500k-1.5MB but still manage-able).
- Perform some masking on individual JPG using the watermark function. At the same time, some JPGs will be added with text using the text function. (File grew to about 1.5MB-2MB)
- Combine each JPG into a multi-page TIF or PDF (either one is fine) using the "-multi" option but the result file grew to about 120-160MB. I tried using compression for TIF but still didn't help much.
Thanks....
Re: Growing Image Size...
Do you use the -c (compression)?
rchu2005
Post by rchu2005 »
xnview wrote:Do you use the -c (compression)?
Thanks for your quick reply, Pierre. Yes I did try -c 7 and -c 8. Any suggestion?
Thanks again.....
Please send me the TIFF that you convert into PDF?
