RC5: Minor Bug in Thumbnail Labels
Locked
Mike2005
Post by Mike2005 »
For JPEGs saved by Photoshop containing EXIF data but NOT the "date taken" field, XnView shows a totally wrong formatted entry for the date taken thumbnail label (e.g. 110/102/2008 111:32) instead of showing nothing.
The picture below shows this issue and will cause it itself.
Re: Minor Bug in Thumbnail Labels
Mike2005 wrote:For JPEGs saved by Photoshop containing EXIF data but NOT the "date taken" field, XnView shows a totally wrong formatted entry for the date taken thumbnail label (e.g. 110/102/2008 111:32) instead of showing nothing.
Could you send me a sample, please?
Post by Guest »
xnview wrote: Could you send me a sample, please?
The sample is the picture I added below my posting. It contains EXIF data but no date taken tag and it will cause the bug described above.
No could you send me the picture, please?
Mike2005
Post by Mike2005 »
@xnview:
I think you didn't understand me right.
The image in my posting is not only showing how the bug is looking like but it itself is also a sample that will cause the bug described above when opened in XnView's browser mode with the thumbnail label "EXIF:date taken" activated.
Nevertheless I sent you an e-mail with an other image attached causing the same error.
Mike2005 wrote:@xnview:
Ok, i've found it
Re: RC5: Minor Bug in Thumbnail Labels
Mike2005 wrote:The picture below shows this issue and will cause it itself.
Verified fixed in RC6 with the above picture. Closed.
Locked
