RC5: Compare Dialog: Close one image
JohnFredC
Post by JohnFredC »
Note: Subject has been renamed from "RC5: Compare Dialog Last Button on Right" to "RC5: Compare Dialog: Close one image"
Say you select 4 images to compare, then decide you don't need to compare one of them. It would be great to be able to remove one image without affecting the other three.
In the Compare Dialog, the last button on the right offers to move the respective image to the recycle bin.
I think that function should be changed (or a new button added) to remove the image from the comparison group.
XnView 1.80 <x>
John
Re: RC5: Compare Dialog Last Button on Right
JohnFredC wrote:Say you select 4 images to compare, then decide you don't need to compare one of them. It would be great to be able to remove one image without affecting the other three.
Perhaps the same as your unlink request...
JohnFredC
Post by JohnFredC »
Hi Pierre!
Well, not exactly. Maybe I used the wrong words.
In my unlink request I was addressing the need to independently recenter one of the images in the Compare and then resume synchronized scrolling of all of them.
This request is for a button (in the compare dialog) to remove an image from a comparison set without deleting it from disk.
John
Dreamer
Post by Dreamer »
JohnFredC wrote:...This request is for a button (in the compare dialog) to remove an image from a comparison set without deleting it from disk.
I suggest to add "Close (image)" also to the context menu for each image.
Button(s) plz. ....
:) Hi again !
- According with the John's request, I would prefer (a) small ‹Close› button(s) on the dialogue itself…
:mrgreen: KR
JohnFredC wrote:Hi Pierre!
Ok, i add it
Dreamer
Post by Dreamer »
Dreamer wrote:I suggest to add "Close (current image)" also to the context menu for each image.
Option above is still missing.
Moved back to "New/Open".
ckit
Post by ckit »
Confirmed - option is still missing RC7 silent release 2.
Nope---
:) Hi !
- Confirmed too : neither buttons, nor menu entry :|
:mrgreen: KR
Nothing---
:) Hi !
- Still missing here in 1.80 final PR. No button, no menu entry…
- In French and in English, hence this has not be added in the program yet.
:mrgreen: K R
ckit
Post by ckit »
In XnView 1.80.1, there is a menu button for "Close image" but there is no context menu entry for it.
