[OK]RC5: Default cache columns are too narrow
Locked
marsh
Post by marsh »
Some columns in cache options are too narrow, the names of these columns cannot be read. They should be spaced apart further apart from each other so at least some of the names can be seen by default.
You can already
:arrow: marsh
:) Hello !
- I can adjust each column in that box using the tab-header… I don't see any problem there.
- Maybe the box-width could be enlarged? But only if you would have very long names / paths… It could be “adjustable”, like some are in the program, for instance the “Open picture”; this is shown by the /// mark at the right lower corner…
:mrgreen: K R
Re: RC5: Default cache columns are too narrow
marsh wrote:Some columns in cache options are too narrow, the names of these columns cannot be read. They should be spaced apart further apart from each other so at least some of the names can be seen by default.
Yes, if you have no cache files, a very little issue :-)
marsh
Post by marsh »
Very true. I guess I needed something to write about. :)
Locked
