RC5: Minor: Remove entry in "Add text" option
Remove entry in "Add text" option after xnview restart, if option "Purge most recent...on exit" is enabled.
Re: RC5: Minor: Remove entry in "Add text" option
Why Add text is not like most recent....Dreamer wrote:Remove entry in "Add text" option after xnview restart, if option "Purge most recent...on exit" is enabled.
I think it's not important, it's almost the same as in Batch Rename, maybe you could add another option to remove all entries in xnview, but I think it's not necessary, you could just remove entry in "Add text" option, if option "Purge most recent...on exit" is enabled.xnview wrote:But Add text is really a history like that???Dreamer wrote:I think, user expect that all "history" entries/items will be removed...
