RC5: Minor: RMB use in selection
Dreamer
Post by Dreamer »
If LMB is used for move picture > RMB is used for move selection (in selection)
If RMB is used for move picture > RMB is used for move picture (in selection)
I suggest the same way, maybe with an option to do both...
Right button use in selection:
- move selection
- zoom in
- move picture
...and add the last option also to "Left button use in selection".
XnView 1.80 <x>
Re: RC5: Minor: RMB use in selection
Dreamer wrote:If LMB is used for move picture > RMB is used for move selection (in selection)
Averyone agree when LMB is used to move picture, LMB must be used too to move selection?
Dreamer
Post by Dreamer »
No, I said, RMB in selection is used for different actions...
Yes RMB is used like "make selection"
Dreamer
Post by Dreamer »
I suggest - always zoom in with LMB and always move selection with RMB - or vice versa if "Left button use in selection" option is set to "Move selection"...
...and maybe add option(s) above.
Dreamer wrote:I suggest - always zoom in with LMB and always move selection with RMB - or vice versa if "Left button use in selection" option is set to "Move selection"...
Ok
Dreamer
Post by Dreamer »
Ok
Not fixed. (Sorry the text above is not correct - "or vice versa if "Left button use in selection" option is set to "Move selection"" shloud be "...is set to "Make selection"")
If LMB is set to make selection - I can't zoom twice and also I can't move selection - :bug: .
Minor - I suggest - Always use (also) LMB to change size of selection.
Moved back to "New/Open".
Dreamer wrote:If LMB is set to make selection - I can't zoom twice and also I can't move selection - :bug: .
Not sure about that. You have CTRL to move selection.
You make selection with RMB, and change selection size with LMB, not sure that it is really good...
Dreamer
Post by Dreamer »
But vice versa it is possible, so just for consistency...
And "I can't zoom twice" is a bug:
- set LMB to make selection
- make selection with LMB
- zoom with LMB
- try to zoom again with LMB
= it doesn't work = :bug:
xnview wrote:
Dreamer wrote:Minor - I suggest - Always use (also) LMB to change size of selection.
So use both, LMB and RMB always to change size of the selection.
ckit
Post by ckit »
Dreamer wrote: And "I can't zoom twice" is a bug:
- zoom with LMB
I can confirm that bug in RC7
Dreamer wrote:And "I can't zoom twice" is a bug:
- zoom with LMB
Sorry i don't understand. When you zoom into selection, the zoom is extended to selected area. So you can't zoom twice...
Dreamer
Post by Dreamer »
- zoom with LMB
Sorry for incorrect information, try again:
- set RMB to make selection
- make selection with RMB
- zoom with LMB (in the middle of the selection)
= it doesn't work = :bug: (there is "zoom in (+)" cursor, but it doesn't work)
- zoom with LMB
Yes, but always you zoom in the selected area, so after you can't zoom more...
Dreamer
Post by Dreamer »
xnview wrote: Yes, but always you zoom in the selected area, so after you can't zoom more...
Yes.
I see now, that it does not matter if I set RMB or LMB to make selection, I can always zoom just once, it doesn't work again.
Yes.
Yes. As Pierre has pointed out already, the Zoom in selection will zoom so that the selection is fully seen. If you zoom again, nothing will happen. This is normal.
Is there any problem left open regarding this? If not, I suggest to move this to Closed/Solved.
