REQ: Tip dialog in menu 'Info'
Locked
The tip dialog should be accessible via a menu item in the menu 'Info'.
That's pretty standard and allows for opening the tip dialog during usage of XnView and reactivating it in case "Do not show this message again" has been checked.
Re: REQ: Tip dialog in menu 'Info'
helmut wrote:The tip dialog should be accessible via a menu item in the menu 'Info'.
Ok, i add it
In RC6, menu entry "Tip of the day..." is available. Closed. :-)
Locked
