[Bug] Resize settings not saved correctly
vaejiofr
Post by vaejiofr »
Starting with XnConvert 1.02, it no longer saves resize settings in scripts correctly. 1.02 added a new "fill" option which I suspect might have broken this.
For example, if I save a script which resizes by "longest side", the next time I load that script, it uses "fill" instead.
Re: [Bug] Resize settings not saved correctly
right
