page selection for .mpo's disabled by embedded comments
Zottt
Post by Zottt »
Since version 1.98 XnView is able to show the different pages of .mpo files.
If you add an embedded comment to a .mpo file the buttons to select the pages are disabled. It is not possible to select the pages any longer.
Re: page selection for .mpo's disabled by embedded comments
you have added an embedded comment with XnView on a .mpo??
Zottt
Post by Zottt »
Yes, it works like a charm.
Ctrl+D and there you go. :?
hum, i'm not sure that editing comment will not remove second image...
Zottt
Post by Zottt »
The second image is fine :P
But i see - i shouldn't do it any longer :|
Zottt
Post by Zottt »
It was fixed with 1.98.1. But 1.98.2 freezes when you add a comment to an *.mpo and have all three boxes checked :? .
Zottt wrote:It was fixed with 1.98.1. But 1.98.2 freezes when you add a comment to an *.mpo and have all three boxes checked :? .
Could you send me a mpo sample?
Zottt
Post by Zottt »
Sorry being late, Pierre.
How can i send the picture? Do you like me to add it to this post? They are pretty large - 3648*2736 :? !
contact at xnview dot com
Zottt
Post by Zottt »
You've got mail Pierre :D
Moderator & Librarian
Zottt
Post by Zottt »
I tried with 1.99.1.
It is a bit weird. At first glance it is possible to set comments (descript.ion) and embedded comments (ctrl D). It appears the mpo's are left intact.
XNView itself still recognizes two frames but doesn't show the second frame any longer :| .
