Moderators: helmut , XnTriq , xnview
Moderator & Librarian
Posts: 6512 Joined: Sun Sep 25, 2005 3:00 am
Post
by XnTriq » Sun Apr 17, 2011 4:45 pm
<!-- Moderator's note: This topic has been split-off from another topic . //-->
Pierre, please fix this in the shell extension, too
Posts: 46236 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Wed Apr 27, 2011 9:04 am
XnTriq wrote: Pierre, please fix this in the shell extension, too
You have the problem with beta 3??
Post
by XnTriq » Wed Apr 27, 2011 11:45 pm
xnview wrote: You have the problem with beta 3??
Yessir. But only with the shell extension.
XnViewShellExt.dll 1.662.976 bytes (13/Apr/2011)
Post
by xnview » Thu Apr 28, 2011 1:16 pm
I've sent you a version to try...
Post
by XnTriq » Sat Apr 30, 2011 9:00 am
xnview wrote: I've sent you a version to try...
Thank you, Pierre.
I've now tested the new DLL on Windows XP SP3 and 2K SP4 (after removing the settings of older versions from the registry).
I still get five zero-length TMPs per MP3 file
Post
by xnview » Mon May 02, 2011 7:16 am
XnTriq wrote: I still get five zero-length TMPs per MP3 file
In '....\Local settings\Temp'?? No TMP files for me...
Could you send me the mp3?
Post
by XnTriq » Tue May 03, 2011 3:00 am
xnview wrote: In '....\Local settings\Temp'?? No TMP files for me...
What about
%WinDir%\TEMP\ ?
xnview wrote: Could you send me the mp3?
Any MP3 will do,
as long as it does *not* have an image embedded in it .
Post
by XnTriq » Sat May 07, 2011 8:30 am
Can really no one reproduce this?
As I said: I have this on XP SP3 (fresh install) and 2K SP4.
Post
by xnview » Sat May 07, 2011 9:31 am
XnTriq wrote: Can really no one reproduce this?
you have always the problem with beta4??
ckv
Posts: 786 Joined: Wed Feb 02, 2005 2:30 pm
Post
by ckv » Sat May 07, 2011 4:07 pm
Indeed.
With the shell extension from beta 4, I get 3 empty temp files in my %temp% directory when right-clicking MP3 files that doesn't contain an embedded picture.
Post
by XnTriq » Sat May 07, 2011 9:00 pm
Thanks for checking, ckv!
