RC4: Message box "Special formats" on double-click
Locked
When double-clicking on a file in MS Explorer to quickly view it in XnView, the message box "Special formats" with the text "By default only the mose common formats...". This message box should only show up if XnView is started using normal menu or program icon. When quickly viewing a file by double-clicking on it, this message box should not appear.
See also topic RC4: Tipp dialog at startup.
Re: RC4: Message box "Special formats" on double-c
helmut wrote:When double-clicking on a file in MS Explorer to quickly view it in XnView, the message box "Special formats" with the text "By default only the mose common formats...". This message box should only show up if XnView is started using normal menu or program icon. When quickly viewing a file by double-clicking on it, this message box should not appear.
right, i fix it
In RC5 this works. Well done, Pierre. :-)
Locked
