Note: Moved - Please - One problem/question per post
Post by Danny
I just found another annoyance. Once the slideshow has started, and you manually switch to the next pictures the counter doesn't restart. So if you stop at a certain picture from which you want the slideshow to go on as normally, that picture may only be on screen for a few milliseconds. So i'd like to request that the counter should be reset each time you manually switch to the next picture.
