1.98 beta - thumbs of 32 bit images dont get shadow
Troken
Post by Troken »
if you look here, you can see it seems that 24-bit images get a drop shadow around the thumb, but not the 32-bit images.
This applies to both JPG and PSD, I have not tested other formats. 1-bit, 8-bit and 48-bit also get the shadow, only 32 dont.
marsh
Re: 1.98 beta - thumbs of 32 bit images dont get shadow
Post by marsh »
With Filter>Effects... it is much the same. Drop shadow doesn't seem to appear on smaller 32 bit png (or new webp) and is incomplete on desktop sized ones (a little shadow seen on 2/3 of lower edge). Don't know about older versions. I only have beta3 installed.
Troken
Post by Troken »
The screenshot is from beta 2, but as you said Marsh, the problem also appears in beta 3.
Yes, for picture with alpha, drop shadow is not drawn, looks not good with...
Troken
Post by Troken »
Im not sure it looks good without. But I guess that it looks weird with some pictures.
