If I press Home or End key twice - a blank screen is shown (in fullscreen lite only).
If I press it again, correct image is shown.
RC4: Minor Home and End key bug
Wierd. I can confirm this, but it occurs only if the folder contains only one picture.
rightmarsh wrote:Pressing <end> key twice goes to ".." folder. It is supposed to display nothing when on "..". But it probably should not go to top of list like it does.
Pressing <home> twice causes first file on list to disappear from status bar.
I'm using this on a directory with multiple images.
Fixed here. Dreamer could you confirm.
