0.35: Please, fix this on 'Recent Files' list
budz45
Post by budz45 »
Look at this picture quickly (click on it)
So for that first Recent File entry that is no longer available in it's file directory (for whatever reason), XnView MP should make it greyed-out and not clickable
Please Pierre, add this small comprehensive enhancement in next or future beta 8)
Re: 0.35: Please, fix this on 'Recent Files' list
You would like that i check every files in history to check if exist?? Can be slow...
budz45
Post by budz45 »
xnview wrote:You would like that i check every files in history to check if exist?? Can be slow...
No no, it doesn't have to do that. It could be as easy as MP detecting that the file in the history list has no icon next to it in the menu (look at this picture again);
Then the file in the history list with no icon mean that it not present anymore, therefore MP could automatically grey that filename out (should be very easy). No need for a history scanner :)
let me know what you think.
Please check XnViewMP 0.38
budz45
Post by budz45 »
Thank you. :D Resolved :D
