Weird clipboard related bug
Drahken
Post by Drahken »
This one may be difficult for you to reproduce & thus difficult or impossible for you to fix, but here goes;
This bug requires firefox 3.6 (probably other versions too, but it definitely happens with 3.6) or opera 10 or 11 (again, probably happens with other versions, but definitely happens with 10 and 11). It also requires the DCE tools photoshop plugin (not sure if the trial version has the same effect or not, I have the full version): http://www.mediachance.com/plugins/dceessentials.html
This bug occurs in 1.98b2
The bug: Go to any image in firefox or opera, right click it & copy it, then go paste it int xnview. Now open up the dce filters and apply one. I believe all of them have the same effect, I know for certain that color corection, autoenhance, and exposure all do.
As soon as you hit the apply button, the top 2/3 of the pic gets all scrambled.
I have tried resizing the pic prior to applying the filter, but get the same result. I have tried several other photoshop filters & none have this issue.
Since this is clearly a clipboard related bug (it doesn't occur if I save the pic & open it in xnview, nor if I paste the pic into another image editor & then re-copy and re-paste into xnview, nor if I copy from internet explorer or chrome), I can't email you any examples.
I'm running windows XP, if that makes any difference.
This bug does NOT occur in xnview 1.97, so it's the result of something that got changed since then.
Due to the rather particular & specific factors involved in this bug, it may be too difficult or impossible for you to track down. Still, I hope that it can be fixed, as I frequently paste images from firefox & then tinker with them.
While I can't send you a sample, due to it being clipboard related, here is what the scrambled pic winds up looking like (hopefully seeing the effect will help you figure it out):
...and this is what it looked like before:
Re: Weird clipboard related bug
Yes, something has changed in clipboard, support alpha channel.
So could you send me your email by PM?
Drahken
Post by Drahken »
This bug is fixed in beta 3.
