Minor omission from GFL SDKs v3.40 LibGfl.pas (Delphi)
varver
Post by varver »
there are some things missing from file GflSDK\Delphi\Include\LibGfl.pas of the GFL SDKs v3.40.
Line 590 is missing the colon (:) marked below, between load_infos and GFL_UINT32
var info: TGFL_FILE_INFORMATION; load_infos: GFL_UINT32): GFL_ERROR; stdcall;
Also, line 1303 (or thereabouts) is missing the following function implementation:
function gflGetFileInformationEx; external GflDLL;
Best Regards,
varver
Re: Minor omission from GFL SDKs v3.40 LibGfl.pas (Delphi)
Thanks
creeek
Post by creeek »
Brilliant , just what i wanted!!!
I Couldnt get this to run at all, due to 2 problems:
1: this one, where colon missing, etc. (thanks)
2: I got a missing libgfl340.dll error, THEN I changed the LibGfl.pas file (line 113) to include the path, e.g. for example
GflDLL = 'D:\Delphi7\GflSDK\Delphi\Demo\Source\libgfl340.dll'; // DLL filename (changed from GflDLL = 'libgfl340.dll' )
There is probably a more elegant way to do this, but it works and compiles, then it even runs!!! amazing, the time I tried to get this working :)
Now the Demo works, I can now experiment with it. (at last!!)
Growing old is mandatory,
Growing up is OPTIONAL!
andrefelix
Post by andrefelix »
I would like to know if someone have it working with Delphi XE.
Today I found this library and couldn't use it yet. I made the fix suggested earlier to compile the unit LibGfl.pas but I still cannot run the demo application.
For example when I run the application I get Runtime error. Using the debugger I could see that there is probably an UNICODE issue.
Is there a Unicode DLL? I'm using Windows 7 32bit and tried adding at the demo directory the DLL's located at Lib and LibW directory from SDK, but same problem.
Then I made changes at the whole LibGfl.pas changing from Char to AnsiChar and PChar to AnsiPChar and at least the function GetFilterString loaded executed correctly, but then when I tried to open a simple JPG file the program showed an error dialog "File not readable: Error to open file".
I tried as well using the Define UNICODE_SUPPORT and removing it, but same issue.
Thx
Mobzga
Post by Mobzga »
I also have the same problem, but found the solution, you need to call unicode (WideChar instead of PChar) functions too.
In the delphi demo file "ImageView_Form.pas" you have this code near line 140:
e := gflLoadBitmap(PChar(filename), gfl_bmp, lp, finfo);
change to this
e := gflLoadBitmapW(PWideChar(filename), gfl_bmp, lp, finfo);
In LibGfl.pas you can find the rest of xxxxW functions you need, just search {$IFDEF UNICODE_SUPPORT} in the file to check them.
You also need the Unicode libs, you can find in \GflSDK\libW
Short instructions from scratch (v3.40):
1.- LibGfl.pas , Line 590 is missing the colon (:) marked below, between load_infos and GFL_UINT32
2.- LibGfl.pas Also, line 1303 (or thereabouts) is missing the following function implementation:
3.- LibGfl.pas add new type workaround: (Line:120)
type
//GPo 2008; Workaround Delphi 2009
  Char = AnsiChar;
  PChar= PAnsiChar;
4.- Libgfl.pas Enable/Uncomment
 {$DEFINE UNICODE_SUPPORT} (Line: 109)]
5.- Use \GflSDK\libW dll's (libgfl340.dll and libgfle340.dll)
6.- Change gflLoadBitmap(PChar(filename) to gflLoadBitmapW(PWideChar(filename) in the "ImageView_Form.pas" demo file near Line:140.
Now you have a working gfl sdk v3.4 on delphi 2009+
