[OK] REQ: Launch Edit fullscreen from browser.
Locked
marsh
Post by marsh »
Just like v.1.74 does.
Danny
Re: REQ: Launch Edit fullscreen from browser.
Post by Danny »
marsh wrote:Just like v.1.74 does.
You mean by default? Dunno.
But you can already set it up as you wish. Options -> General -> Switch mode.
P.S.: What you call "edit fullscreen" is now simply called "edit mode".
Dreamer
Post by Dreamer »
Danny wrote:P.S.: What you call "edit fullscreen" is now simply called "edit mode".
No "Edit mode" is Viewer! It is confusing for some users...
...continue here RC3: New names for 2 Fullscreen modes and Viewer?
With option: "Switch between Browser, Edit mode and Fullscreen" you can use only "old" Fullscreen mode, but there is a known bug there...
marsh
Post by marsh »
Except that View in Fullscreen is not viewer.
Dreamer
Post by Dreamer »
I misunderstood.
There are few known bugs in "Switch mode" options - more here.
Why do you want open your picture in EDIT mode and in fullscreen??
Dreamer
Post by Dreamer »
Pierre, I think "Switch between Browser, Edit mode and Fullscreen" will be enough, we can continue here, if you'll fix bug with that option...
marsh
Post by marsh »
I frequently crop photos and prefer to actually see what I am selecting in fullscreen. I think any work which can be accomplished in fullscreen is easier and looks better than just using a program's work window. So, I enjoy how v.1.74 works (switching back and forth from browser to EDIT fullscreen).
marsh wrote:I frequently crop photos and prefer to actually see what I am selecting in fullscreen. I think any work which can be accomplished in fullscreen is easier and looks better than just using a program's work window. So, I enjoy how v.1.74 works (switching back and forth from browser to EDIT fullscreen).
Ok, so often you have the browser, click on a thumbnail to edit it in fullscreen, back to normal, save it and return to browser, right?
marsh
Post by marsh »
Yes, that is what I often do.
Dreamer
Post by Dreamer »
I think, new option "Switch between Browser>FS>Viewer" is enough, marsh??
marsh
Post by marsh »
Dreamer wrote:I think, new option "Switch between Browser>FS>Viewer" is enough, marsh??
As currently implemented in RC5, I'm satisfied with "Use ENTER to switch between Browser, Fullscreen, and Viewer."
Locked
