Beta 2 : -info doesn't return anything
Mistic100
Post by Mistic100 »
So I'm trying the beta 2 (for iptc processing)
but while reading files infos, nconvert doesn't return anything, either without the -iptc_print param
my simple test code
nconvert.exe -info "img.jpg"
works with v5.75, but no with 5.85
it just return the first three lines
array(4) {
  [0]=>
  string(75) "** NCONVERT v5.85 (c) 1991-2010 Pierre-E Gougelet (Mar 10 2011/13:31:59) **"
  [1]=>
  string(72) "        Version for Windows NT/9x/2000/Xp/Vista/7  (All rights reserved)"
  [2]=>
  string(55) "** This is a freeware software (for non commercial use)"
  [3]=>
  string(0) ""
edit : it appears that the whole program is buggued (I think) even a simple jpeg compression doesn't works...
error while compiling ?
Re: Beta 2 : -info doesn't return anything
Yes, please redownload the package, a problem in the build :(
Mistic100
Post by Mistic100 »
ok -info works
lossless -iptc_add/set/clear too
but -iptc_print doesn't :(
nconvert.exe -info -iptc_print 25 "img.jpg"
juste returns the three license lines
Please remember to update the copyright year, Pierre. Currently it still says: "** NCONVERT v5.85 (c) 1991-2010 Pierre-E Gougelet (Mar 10 2011/13:31:59) **"
Mistic100 wrote:ok -info works
right :(
Please try 1.98 beta3
Mistic100
Post by Mistic100 »
works fine
