[Fixed] Beta 1: Empty temp files left behind when browsing
ckv
Post by ckv »
I noticed that after browsing folders that contain MP3 files with the XnView 1.98 beta 1, there was a lot of empty temp files with name format x_###.tmp in my temp directory.
I think XnView creates a temp file for each MP3 file in the browser and doesn't delete it after it's no longer needed. :bug:
Re: Beta 1: Empty temp files left behind when browsing
Could you try XnView 1.98 beta 2
ckv
Post by ckv »
xnview wrote:Could you try XnView 1.98 beta 2
Fixed. Thanks. :)
