[Fixed in RC6] "EXIF: Flash mode"
Lesmo16
Post by Lesmo16 »
I like to request the additional thumbnail label EXIF: Flash mode
With this label it should be easier to compare two pictures of the same object - one taken with, the other without flash.
Everyone who believes in telekinesis, raise my hand!
ckit
Post by ckit »
PLEASE don't post anymore NEW bugs & requests before RC4
http://newsgroup.xnview.com/viewtopic.php?t=2187
Lesmo16
Post by Lesmo16 »
Oops - sorry! :?
Re: [REQ:] Thumbnail label "EXIF: Flash mode"
Lesmo16 wrote:I like to request the additional thumbnail label EXIF: Flash mode
Ok, i'll add it
Lesmo16
Post by Lesmo16 »
Ok, i'll add it
Yes, you did! Thanks Pierre. :)
Unfortunately there is a little 'but': :wink:
You've built in the EXIF tag [0xb001c] (Flash activity), which returns "fired" or "not fired".
What I've meant is the EXIF tag [0x9209] (Flash), which returns "On, Auto mode", "Off, Auto mode", ....
This tag gives information if the flash was fired and additionally which mode was used.
Ok, i'll add it
No, i use the EXIF tag 0x9209, and there is no 0xb001c tag...
Lesmo16
Post by Lesmo16 »
xnview wrote:No, i use the EXIF tag 0x9209, and there is no 0xb001c tag...
Then tag 0xb001c must be from my Canon Ixus 400. :wink:
:arrow: Would you please change the shown string form "Not fired" to "No Flash" :?:
I found this about flag 0x9209 - perhaps it's useful for you.
PropertyTagExifFlash - Flash status.
This tag is recorded when an image is taken using a strobe light (flash). Bit 0 indicates the flash firing status, and
bits 1 and 2 indicate the flash return status.
Tag 0x9209 - Type PropertyTagTypeShort - Count 1
Values for bit 0 that indicate whether the flash fired:
0b - flash did not fire
1b - flash fired
Values for bits 1 and 2 that indicate the status of returned light:
00b - no strobe return detection function
01b - reserved
10b - strobe return light not detected
11b - strobe return light detected
Resulting flash tag values:
0x0000 - flash did not fire
0x0001 - flash fired
0x0005 - strobe return light not detected
ok
Dreamer
Post by Dreamer »
Lesmo, could you tell me what [OK!] means? Should I move this topic to "Closed/Solved", or Pierre will add your feature?
Lesmo16
Post by Lesmo16 »
Dreamer wrote:Lesmo, could you tell me what [OK!] means? Should I move this topic to "Closed/Solved", or Pierre will add your feature?
Both! :wink:
Dreamer
Post by Dreamer »
Both! :wink:
But I can't move it to "Closed" if it's not 'retested'...
scratch
Post by scratch »
if pierre's going to fix it, then it should be moved to "fixed in rc6", no?
Lesmo16
Post by Lesmo16 »
Dreamer wrote:
Both! :wink:
Dreamer, please move this thread like scratch suggested.
Dreamer
Post by Dreamer »
scratch wrote:if pierre's going to fix it, then it should be moved to "fixed in rc6", no?
No, in "fixed in rc6" forum are just fixed bugs.
Only Pierre can move this topic to "fixed in rc6" forum if he will fix it.
Lesmo16
Post by Lesmo16 »
Lesmo16 wrote:Would you please change the shown string form "Not fired" to "No Flash"
xnview wrote:ok
This is the last state.
I understood Pierre's OK, as if we can await this small correction in RC6.
So please decide what to do with this thread, because I don't know the modalities. :?
Locked
