I don't understand the use of saving and loading script in XnConvert (the save button is inactive). Is the function implemented ?
Save batch script: Icon disabled all the time
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
- Moderator
Re: Save script
Works fine for me in v0.84 and XnConvert 1.73: The Icon for saving is enabled all the time.
Note: The icon's blue color is a little bit bright and thus one could think it's disabled.
Closed (Please post here in case the problem should occur again)
