[Fixed] RC3: Shift Key selection not sticking in Fullscree
Locked
marsh
Post by marsh »
In FullScreen-Lite mode, scanheaders on. Details view. When returning back to browser after advancing a number of files, I attempt to hold down shift key while pressing up arrow so that previous viewed files can be selected. This is an impossible task however, since the position is not held on the last file viewed. Standard Fullscreen mode functions properly when selecting files in browser's detailed file list this way.
Re: RC3: Shift Key selection not sticking in Fullscreen-Lit
marsh wrote:In FullScreen-Lite mode, scanheaders on. Details view. When returning back to browser after advancing a number of files, I attempt to hold down shift key while pressing up arrow so that previous viewed files can be selected. This is an impossible task however, since the position is not held on the last file viewed. Standard Fullscreen mode functions properly when selecting files in browser's detailed file list this way.
You are in details view, you go in fullscreen, change picture, and when you go back to the browser you have no more the selection, right?
Dreamer
Post by Dreamer »
xnview wrote:You are in details view, you go in fullscreen, change picture, and when you go back to the browser you have no more the selection, right?
If so, I can't confirm.
Dreamer
ckit
Post by ckit »
1. In XnView, Browser Mode (Details View, Fullscreen Lite mode, Scan Headers: Always)
2. Double-click on a file
3. Viewing in Fullscreen
4. Go forward by pressing space a couple of pictures
5. Right-click -> Fullscreen off
6. Press Shift+Up and 10 files are automatically selected?
That's my research.
ckit wrote:1. In XnView, Browser Mode (Details View, Fullscreen Lite mode, Scan Headers: Always)
That's my research.
Right for this bug
marsh
Post by marsh »
Not quite, when I go back to browser, I begin to make my selection by pressing shift + up arrow. The shift key basically does not work doing this in fullscreen-lite. I believe I have seen this bug in very old versions of Xnview.
Locked
