Broswer preview zoom menu bug
Locked
Andy
Post by Andy »
Someone please verify this behavior.
In the browser with the preview visible, if you choose the View menu and scroll to the Preview submenu and then to the Zoom submenu, the checkmark indicating what zoom factor you're in does NOT show.
This is also true if you right-click in the Preview Window and use the same hierarchacal Zoom submenu.
Thanks,
Andy
XnView 1.80 <x>
marsh
Post by marsh »
If your talking about the submenu going from 1600% to 7%, then you are right, it does not track current zoom view. Is it supposed to? I do notice the lower numbers of this menu do not match the zoom numbers displayed on status bar either (which show 25, 17, 12, 8, 6 not same as 25, 20, 15, 10, 7). v.1.74 acts the same way.
marsh wrote:If your talking about the submenu going from 1600% to 7%, then you are right, it does not track current zoom view. Is it supposed to? I do notice the lower numbers of this menu do not match the zoom numbers displayed on status bar either (which show 25, 17, 12, 8, 6 not same as 25, 20, 15, 10, 7). v.1.74 acts the same way.
Yes, not sure that i must check it
Locked
