ToDo list
Re: ToDo list
Post by xnview » Fri Jan 18, 2019 10:40 am
wfa wrote:
Fri Jan 18, 2019 4:30 am
Add to Text action:
Proportional text size based on the image dimension. This prevents long text (in case of for example Folder name) from going outside the image.
you can choose unit %
wfa
Re: ToDo list
Post by wfa » Fri Jan 18, 2019 4:06 pm
If percentage is meant to be proportional to the image size then it didn't work.
Re: ToDo list
Post by xnview » Sat Jan 19, 2019 8:22 am
could you send a screenshot?
wfa
Re: ToDo list
Post by wfa » Sat Jan 19, 2019 11:43 am
It worked. My mistake was using whole numbers. But when I used 1.5% it worked.
Thanks for the follow-up. Should I delete my original post?
Sablesword
Re: ToDo list
Post by Sablesword » Sat Mar 30, 2019 5:22 pm
Add to Text action:
As nearly as I can tell "unit %" scales the text based on the image's height. Is this correct?
And if so, is there any way to scale text based on the image's width?
Re: ToDo list
Post by xnview » Sun Mar 31, 2019 9:13 am
currently no way
