ToDo list
ToDo list
Post by xnview » Tue Feb 08, 2011 8:45 am
* multi-core support for linux & macosx (already for windows)
* option to check if resize argument is smaller or not than current picture file (no actions in this case)
* skip files smaller/larger than user size for resize
* lossless rotate
* xnconvert -script myscript.xbs
* Different view mode for filelist
* ini in program folder
* GIF=>APNG
* Drag&Drop folders
* 8bf plugin
* archive support
(# added for next version)
Peter2
Re: TODO
Post by Peter2 » Thu Feb 10, 2011 9:04 am
Cropping:
- Add units to the Crop - settings
- add a symbol for coordinate-pane (0,0 and directions of X and Y)
Peter
XnView 2.48 German, Win 7 x64 Prof. / Win 10
lukoie
Re: ToDo list
Post by lukoie » Thu Jun 02, 2011 2:47 pm
Please,
* Send on FB/Flickr/Picasa/FTP
at least it is possible to do in XnView
And please, add the "tile" option to watermarking
thanx
MaxSt
Re: ToDo list
Post by MaxSt » Wed Jun 08, 2011 2:18 pm
xnview wrote: * GIF=>APNG
My converter is under zlib license now, so feel free to use it.
Re: ToDo list
Post by xnview » Thu Jun 09, 2011 7:10 am
Thanks! :)
MaxSt
Re: ToDo list
Post by MaxSt » Fri Jun 10, 2011 7:06 pm
You're welcome.
Such conversion can be tricky when you need to join different local palettes, especially when transparency colors are different for each frame.
derelict
Re: ToDo list
Post by derelict » Sun Jun 12, 2011 8:50 pm
Hi, this is a very nice program! I would like to make a small suggestion for an option in the resize processing to skip files that are already smaller than the resize dimensions if reduce only is selected.
matob
Re: ToDo list
Post by matob » Tue Jun 14, 2011 8:19 am
Please add a switch to keep the original file if size is smaller and no actions applied.
Re: ToDo list
Post by xnview » Wed Jun 15, 2011 7:02 pm
@matob, @derelict: So an option to check if resize argument are smaller or not than current picture file? (if true, no action)
matob
Re: ToDo list
Post by matob » Thu Jun 16, 2011 11:36 am
xnview wrote:@matob, @derelict: So an option to check if resize argument are smaller or not than current picture file? (if true, no action)
Example scenario in my case:
- Action - Resize, 800x600, Reduce only
- Output - Jpg, Q80, ...
Files -> outcome
1.jpg, 1024x768, 2 MB -> 800x600, 1MB
2.jpg, 800x600, 2 MB -> 800x600, 1MB
3.jpg, 800x600, 500kB -> 800x600, 1MB - do nothing, keep original file because is smaller and no action are applied
derelict
Re: ToDo list
Post by derelict » Sun Jun 19, 2011 10:37 pm
Hi, yes an option to check if resize argument is smaller or not than current picture file? (if true, no action) would be a nice addition. Thanks for considering our suggestion!
lian
Re: ToDo list
Post by lian » Fri Jul 01, 2011 5:54 pm
I would like a launching with particular script so I can do shortcuts of the program with the script corresponding.
SF, illustrations et mes BD sur mon blog: http://www.li-an.fr/blog
Windows 10 Home 64 bits
budz45
Re: ToDo list
Post by budz45 » Sun Jul 17, 2011 3:12 pm
Hi Pierre,
It would be nice if you could add my two very last feature requests for XnConvert, which are these two:
budz45 wrote: Subject: My feedback so far for XnConvert
11.) Reset window title to default after converting - for this, I would suggest that a user could click on any of the other tabs ('input', 'actions', 'output' or 'about') and then this would reset the window title back to default window title :) It's a use would be better visually show to the user that XnConvert is ready for more conversion sessions rather than always displaying "finished" all the time.
12.) A tickbox setting in the "output" tab called 'Clear all file items in input' - if enabled this would simply auto-remove all images in the "input" tab after each/any conversion finished. I made it here; http://i55.tinypic.com/2rfaoti.png :)
I think the users would like these two small features :) XnConvert is a wonderful standalone batch converter, it's a pleasure to use the app and support your development.
robertho
Re: ToDo list
Post by robertho » Mon Aug 01, 2011 5:10 pm
I was thrilled to see EXR support. but it looks like it is for 'read' only.
will there be EXR support to write the filers?
I am planning to convert .cr2 Raw filers to exrs without any filter. Just the raw debayering.
IS there a plan to implement this?
cheers,
Robert
lathander
Re: ToDo list
Post by lathander » Tue Sep 20, 2011 4:50 pm
I'm still waiting for "Reset EXIF orientation value" from XnView :(
