RC3: Resize dialog hides mousecursor
Locked
deus-ex
Post by deus-ex »
Uppon invoking the Resize dialog [Shift-S] the mousecursor gets hidden after a slide delay which makes it impossible to pick a selection from the dialog.
While all items of the Resize dialog are also selectable with the keyboard this is not true for the 'Standard Size' dropdown list which can only be accessed with the mouse.
The latter issue is also to be found in earlier releases of XnView.
Regards,
deus-ex
Re: RC3: Resize dialog hides mousecursor
deus-ex wrote:Uppon invoking the Resize dialog [Shift-S] the mousecursor gets hidden after a slide delay which makes it impossible to pick a selection from the dialog.
Right
Dreamer
Post by Dreamer »
Fixed in RC4.
Locked
