RC3: Switch forward doesn't work with videos
Locked
Dreamer
Post by Dreamer »
If the next file is video, I can't switch forward / to the next file - with PgDown, right arrow, mouse wheel.
I can switch backward without any problems with all keys / mouse.
Edit:
It doesn't work also with default settings, but it's really strange, sometimes only PgDown/Right doesn't work, sometimes all keys and sometimes only mouse wheel doesn't work.
I think something is wrong with new not white background colour.
Very important - it doesn't work in fullscreen lite only !
This bug is only in RC3.
Not here....
:) Hi !
- I cannot confirm this under Win 98 SE, it works fine with PgeUp/Down, as well for Next file than for Previous file; I have only a <vgany3.mpg> video in that folder… What extension are causing that at your's ?
- I use L/R arrows to scroll the image, not to browse the directory…
- It works fine too with the buttons of the bar.
- I use the mouse wheel to scroll the image, not to browse the dir. .
:mrgreen: K R
marsh
Post by marsh »
I cannot recreate this either. I can move forward and backwards over a video perfectly.
marsh wrote:I cannot recreate this either. I can move forward and backwards over a video perfectly.
Also works for me. Perhaps this problem can be seen only in combination with a specific option set/unset.
@Dreamer: Could you provide us your xnview.ini?
Dreamer
Post by Dreamer »
I sent my .ini file to Pierre for another problem...
marsh
Re: RC3: Switch forward doesn't work with videos
Post by marsh »
I can confirm that Fullscreen-Lite does pass over AVI videos when moving forwards or backwards in a group of files. RC3.
Dreamer wrote:If the next file is video, I can't switch forward / to the next file - with PgDown, right arrow, mouse wheel.
Ok, right when you are in detail view
ckit
Post by ckit »
This bug is still present in RC4.
I can't move forward using the mouse wheel or Page Up.
Dreamer
Post by Dreamer »
ckit wrote:This bug is still present in RC4.
Confirmed.
Moved back to "New/Open" forum.
Dreamer
Post by Dreamer »
Fixed in RC5.
ckit, could you retest too? It's a strange bug...
ckit
Post by ckit »
Page Up now works like Page Down (View mode and Fullscreen)
A side issue, the volume starts out at 0%,
I bring it up to 100% and it drops back to 80% on it's own.
Locked
