RC3: Add "Properties" also for folders
Dreamer
Post by Dreamer »
Add "Properties ... Alt+Enter" also for folders, e.g. standard Windows Properties dialog, reason, e.g. if I want check the folder size - there is no other way.
ckv
Post by ckv »
I agree.
Good suggestion, Dreamer. If possible this should make it into 1.80.
ckit
Post by ckit »
I agree, good suggestion.
This would allow you to change folder attributes and stuff.
helmut wrote:Good suggestion, Dreamer. If possible this should make it into 1.80.
Ok, i'll add it
ckit
Post by ckit »
This has been added to RC4, for the treelist you have to press ALT+Enter there is no menu method.
ckit wrote:This has been added to RC4, for the treelist you have to press ALT+Enter there is no menu method.
Ok, i add an item in the tree menu.
Dreamer
Post by Dreamer »
Added in RC5.
Please retest - and enjoy :wink: ...
Nice---
:) Hello !
- It works fine here under Win98 SE…
:mrgreen: K R
The Properties dialog for folder is available using the context menu.
But when pressing Alt + Enter nothing happens. Does this work for other people?
Nope !
:) Hi !
- Right, the shortcut Alt+Enter doesn't work at all… Win 98 SE
:mrgreen: KR
helmut wrote:The Properties dialog for folder is available using the context menu.
Strange, Alt+Enter works for me...
Not stolen here…
:) Hello Pierre !
- Sometimes, some shortcuts are "stolen" by a running device, the most times a bunch of "Options" for the graphic-card … We see that often in Total Commander i.e. for Alt+F5
- But this is not the case @ home, the graphic-card is built-in the Intel™ MB, and these features are pretty disabled in the manager… ???
:mrgreen: K R
Olive
Post by Olive »
For me Alt+Enter works in browser but doesn't work in folder tree. RMB>Properties works in both.
Olive wrote:For me Alt+Enter works in browser but doesn't work in folder tree. RMB>Properties works in both.
ok
Locked
