RC3: Gamma in slide.exe?
Locked
marsh
Post by marsh »
Should gamma settings be applied to slide.exe? Or gamma controls?
When giving a slide.exe to someone else, they would not want gamma properties transfered to slide.exe because monitors would not share same properties. But it might be useful for single user on single computer. Gamma controls would be useful if other user knew what they were.
Re: REQ: Gamma in slide.exe?
marsh wrote:Should gamma settings be applied to slide.exe? Or gamma controls?
Perhaps an option/Slideshow/Use gamma value will be better. What do you think?
marsh
Post by marsh »
xnview wrote: Perhaps an option/Slideshow/Use gamma value will be better. What do you think?
Yes. That would be better.
I'll add gamma support in slideshow too
Now, there is a setting "Use Gamma setting in EXE/.scr". Closed.
Locked
