[Fixed BUT] RC3: Bug with Exit in the context menu in Browse
Locked
Dreamer
Post by Dreamer »
Pierre, thank you very much for Exit option in the context menu :)
I have little suggestion - could you add it also to Browser context menu? I think also "Stop... ESC" doesn't work good, so it could be replaced with Exit if it is enabled (current option). But it's not so important...
In the browser, when I exit xnview with Exit in the context menu from Preview, Browser shrink preview (and Folder tree) at next start.
Exit in the context menu in Viewer, Fullscreen standard and lite works good.
Re: RC3: Bug with Exit in the context menu in Browser
Dreamer wrote:Pierre, thank you very much for Exit option in the context menu.
Yes. And good that it is an option (General, "Add Exit to Popup Menu (view & Fullscreen"). ;-)
A better name for the option would be "Add 'Exit' to context menus (View & Fullscreen)".
Draemer wrote:I have little suggestion - could you add it also to Browser context menu?
Makes sense. Then it's available everywhere.
Draemer wrote:I think also "Stop... ESC" doesn't work good, ...
Yes. It should be removed.
Draemer wrote:..so it could be replaced with Exit if it is enabled (current option). But it's not so important...
No. If you change an option, only one specific thing should be affected, not two. Otherwise people will not understand.
Dreamer
Post by Dreamer »
Helmut,
I agree with you, but what about that bug?? Can you confirm it?
Dreamer wrote:I agree with you, but what about that bug?? Can you confirm it?
Easy to reproduce. Confirmed. :bugconfirmed:
Dreamer wrote:In the browser, when I exit xnview with Exit in the context menu from Preview, Browser shrink preview (and Folder tree) at next start.
Right, i'll fix it
Dreamer
Post by Dreamer »
Right, i'll fix it
Fixed in RC4, thanks.
And what about this:
Dreamer wrote:And what about this:
There's a new topic for the Exit menu item. Closed.
Locked
