[Fixed] RC3: different Fullscreen-View with Enter or Double
Locked
deus-ex
Post by deus-ex »
Following option are enabled:
* General\Startup\Start View in Fullscreen
* Browser\Double-click or enter to view in fullscreen
Entering on image does'nt go fullscreen but with Title-/Menu-/Tool-/Tabs-/Statusbar enabled.
Doubleclicking on image goes fullscreen but does'nt take setting View\AutoImageSize into
account, i.e. setting "Fit image to window, all" has no effect.
Regards,
deus-ex
Re: RC3: different Fullscreen-View with Enter or DoubleClick
deus-ex wrote:Following option are enabled:
Yes, currently the lite fullscreen takes fit option from preview.
Perhaps a good idea to use same fit option as normal fullscreen.
Anyone agree?
deus-ex
Post by deus-ex »
Agreed. :)
Regards,
deus-ex
Dreamer
Post by Dreamer »
Me too.
Danny
Post by Danny »
Regards,
deus-ex
For me it already does. But then again, my preview-zoom setting is "same as view". That may explain it.
deus-ex
Post by deus-ex »
xnview wrote:Yes, currently the lite fullscreen takes fit option from preview.
Anyone agree?
I searched for this setting in the config dialog several times without success. At last i found it in the Menubar under \View\Preview\Auto Image Size\.
Honestly i would expect such settings to also appear in the config dialog. It never came to me to look for settings which are only to be found in the Menu.
So i'd like to ask you to add such settings to the config dialog too, please.
Regards,
deus-ex
Dreamer
Post by Dreamer »
Fixed.
No more bugs here?
deus-ex
Post by deus-ex »
Fixed.
Regards,
deus-ex
Locked
