RC3: Minor Issue with Shell New Template XNVIEW.BMP
Locked
ckit
Post by ckit »
Any chance the shell new template "XNVIEW.BMP" can be renamed to "XnView Bitmap" or something that looks nice.
Another issue, when using this template it creates files called "New XNVIEW.BMP.bmp"
This needs to be seriously re-worked. Should be called "New XnView Bitmap.bmp"
Sigh, looking at that screenshot the developers behind WinRAR need to get their act together as well :(
Re: RC3: Minor Issue with Shell New Template XNVIEW.BMP
ckit wrote:Any chance the shell new template "XNVIEW.BMP" can be renamed to "XnView Bitmap" or something that looks nice.
You means file type in associations??
ckit
Post by ckit »
Yes, I only noticed after I associated XnView with my graphics files.
ckit wrote:Yes, I only noticed after I associated XnView with my graphics files.
Ok, i'll change the label
ckit
Post by ckit »
This is fixed in RC4 after unchecking BMP and re-checking BMP in Associations. Nice work :)
Locked
