MP 0.31 on Win 7 questions
bucky
Post by bucky »
Longtime xnview user, but new to MP; I started trying MP out for the unicode support. I played around with it, searched in the forums for some answers, and have these questions:
1. Lock Zoom: I can only get it to work when I set Auto Image Size = No Fit. It doesn't seem to work in my usual mode "Fit image to window".
2. When I zoom in to 150% or 250%, I see black gridlines.
3. Is there a way to use keyboard to pan when zoomed in?
4. Can I zoom into the center of the image rather than upper left corner?
5. Can I use keyboard Alt+I to access the Image menu?
6. Can it play AVI videos?
7. Is there a way to show the filename in the title bar in viewer mode?
These are all functions that I was used to in xnview 1.97, so I was hoping I could do with MP as well.
Re: MP 0.31 on Win 7 questions
bucky wrote:1. Lock Zoom: I can only get it to work when I set Auto Image Size = No Fit. It doesn't seem to work in my usual mode "Fit image to window".
Right, 'Lock zoom' must reset 'auto image size'
A known issue
No
You means when you use 'zoom in'?
Ok, a bug
Yes
Currently not possible
