RC4: Only one instance and Send to XnView
Locked
ckv
Post by ckv »
If XnViews 'Only one instance' option is on and I try to send a dirctory to XnView by using Windows Send to menu link XnView gives 'illegal operation'. Sending files works just fine.
Edit: Oh yeah! I forgot very important thing! XnView have to be all ready running when sending the directory to XnView.
Tested on Win98 so could someone confirm this?
(I could test it also in XP but my little sister is having msn maraton :mrgreen: )
Edit:
When sendin picture to Xnview Size/pos fullscreen options are ignored
_ :bug::bug: ___ :bug: _ :bug: __ :bug: ___ :bug:
:bug: ______ :bug::bug: _____ :bug: _ :bug:
:bug: ______ :bug::bug: ______ :bug::bug:
_ :bug::bug: ___ :bug: _ :bug: _____ :bug:
Re: RC3: Only one instance and Send to XnView
ckv wrote:If XnViews 'Only one instance' option is on and I try to send a dirctory to XnView by using Windows Send to menu link XnView gives 'illegal operation'. Sending files works just fine.
Ok, i'll fix it
ckv
Post by ckv »
Not fixed in RC4 when using win98. In XP it works well.
And when sendin picture to Xnview Size/pos fullscreen options are ignored
ckv wrote:Not fixed in RC4 when using win98. In XP it works well.
Ok, right crash in win98.
But what is size/pos problem???
Post by Guest »
xnview wrote:Ok, right crash in win98.
Yeah, crash in win98.
I was on hurry when I posted that size/pos bug. What I really ment abot that size/pos thinngy was that when XnView is in fullsize window it will remember that on next time when you run it, but if I send picture to XnView by using windows send to menu it will not open in fullsized window. If I send a directory in the same way it will work just fine.
And by the way XnView RC4 saves it's size/pos also in fullsized window RC3 didn't save.
ckv
Post by ckv »
Damn I never remember to log in. :D
Just want to add to the previous that the 'Maximize XnView at Startup' have to be naturally unchecked.
Edit:
That 'XnView RC4 saves it's size/pos also in fullsized window' occur s only if browser is set to launch at startup and it occurs also in RC3 (sorry), but not if the browser is set not to launch at startup. :)
Edit: Too much drinking may cause funny typos when writing.
ckv wrote:Damn I never remember to log in. :D
Edit:
Ok, i fix it
ckv
Post by ckv »
All these bugs are fixed in RC5. :D Thanks Pierre.
Locked
