RC3: No thumbnail for files larger than [____] KB
EgoSun
Post by EgoSun »
Image Image
Blue area: the option has a value of 2048 KB, but as you see it on the second screeshot, xnview still shows thumbnail for 45 MB file.
True !
:) Hello !
- I can confirm that !
- I get a thumbnail for a 2.77 MB picture, while the setting is max. 1 MB (1,024 Kbytes)
:mrgreen: Kind regards,
ckit
Post by ckit »
I can confirm as well.
Perhaps the thumbnail is already in cache files, so in this case you have the thumbnail. Try with an empty cache.
ckit
Post by ckit »
I've never had caching enabled and I have the bug!
Sorr i can't reproduce it. Could you remove cache folder, and try again?
Olive
Post by Olive »
This option does nothing for me neither. Even if I removed all from cache, every thumbnail would still be displayed whichever the filesize.
ckit
Post by ckit »
I deleted the whole cache folder and the bug is still there.
Olive wrote:This option does nothing for me neither. Even if I removed all from cache, every thumbnail would still be displayed whichever the filesize.
Which filesize do you used as limit?
ckit
Post by ckit »
I used 1024kb which is the default.
Test file was 1.71Mb in size.
EgoSun
Post by EgoSun »
BTW, I suggest to rename this option to: No thumbnail for files larger than [____] KB. It just sounds better.
Ok, now i understand. for other files, xnview takes the thumbnail from windows explorer. So XnView doesn't create thumbnail for this file.
Perhaps it's better to use the same option for others files??
EgoSun
Post by EgoSun »
I have thumbnail caching disabled in windows explorer either.
Hacker
Post by Hacker »
xnview wrote:
ckit wrote:
xnview wrote: Which filesize do you used as limit?
For what "other" files? Which files are "other"? BMP, as in EgoSun's example?
Roman
Hacker wrote:For what "other" files? Which files are "other"? BMP, as in EgoSun's example?
If the files has not a good size (like here) then i ask the system to gets the thumbnail.
Locked
