v.0.31w Web capture and https
marsh
Post by marsh »
When using web capture tool upon an https link, the progress indicator does not end.
Sample location:
Throbber Button :: Add-ons for Firefox
jamaro
Re: v.0.31w Web capture and https
Post by jamaro »
Hello. I'm new as writer on this forum, but an old XnView user.... I LIKE IT!
- I found the same bug mentioned above, and...
- The dialog box "WebCapture" resizes with the URL entered. If the URL is long, the width of the dialogue off the screen.
For example, a link of GoogleMaps like: http://maps.google.es/maps?f=d&source=s ... 764648&z=6
Also, In this case the capture does not show the journey calculated and you can see at the picture top "Cargando/Loading ...". It seems that capture is complete prior to loading the page.
- One question: Is it possible to empty the captured web history?
Regars,
jamaro
Yes, currently it's normal. My version of QT is without OpenSSL
