[Fixed] RC3: Quickslideshow toolbar button sometimes does n
Locked
marsh
Post by marsh »
Sometimes the Quickslideshow toolbar button does not work. It raises up, but sometimes it does not stop show. My delay setting is at 400 ms.
Re: RC3: Quickslideshow toolbar button sometimes does not st
marsh wrote:Sometimes the Quickslideshow toolbar button does not work. It raises up, but sometimes it does not stop show. My delay setting is at 400 ms.
In view mode?
marsh
Post by marsh »
In view mode?
Yes. I just started with space-bar and it had trouble stopping with mouse.
Main button
:arrow: marsh
:) Hello !
- I tested the same just now: It stops with the mouse striking the main button which acts as “bistable”, not the small subsidiary one… :wink:
:mrgreen: Kind regards,
marsh
Re: Main button
Post by marsh »
Clo wrote::arrow: marsh
:) Hello !
I was using the main button, not the arrow next to it. The button raised up but did not stop show. This is part of screenshot with show running:
Re: Main button
:) Hello !
I can't reproduce it. Which delay do you use?
So you start quick slideshow with SPACE and try to stop it by icon in toolbar, right?
marsh
Re: Main button
Post by marsh »
xnview wrote: I can't reproduce it. Which delay do you use?
Yes. QuickSlideShow>delay(ms).....600 or 400.
Re: Main button
I'll fix it
Think marsh has changed the subject to "[Fixed]", so I close this one.
Locked
