RC3: Auto Image Size - No Fit problem
Locked
ckit
Post by ckit »
1. In xplorer2 (or any file manager)
2. Double-click on a file
3. In XnView, View Mode
4. Auto Image Size is set to "Fit image to window, large only"
5. I change it to "No Fit" and nothing happens!
The zoom counter down the bottom stays at 80% instead of going to 100%
Dreamer
Post by Dreamer »
No fit = Zoom 100% ? If so I can confirm this, <*> key works good.
Re: RC3: Auto Image Size - No Fit problem
ckit wrote:1. In xplorer2 (or any file manager)
Hum not sure that i must reset the zoom to 100%, "Not fit" specify only that the zoom must no be changed when window size change...
ckit
Post by ckit »
This bug is still present in RC4.
-1. In XnView -> Options -> View Mode ->
-2. Set "Auto Image Size" to "Fit image to window, large only"
-3. Exit XnView
2. Double-click on a file -> XnView loads the file into View Mode
3. Goto Zoom button on toolbar and select "No Fit"
Nothing happens!
ckit wrote:This bug is still present in RC4.
-3. Exit XnView
Nothing happens!
But no fit don't reset zoom, it's normal.
ckit
Post by ckit »
With a small image it's normal but not when it's a large image. If I were to reverse the process and start out with "No Fit" and XnView loaded it, it would be 100% instead the 51% I keep getting.
Dreamer
Post by Dreamer »
ckit, try to click on that Zoom button, it's not the Zoom button but "Zoom 100%" button.
To prevent confusion I suggest to add "Original size - 100%" also to sub-menu.
ckit wrote:With a small image it's normal but not when it's a large image. If I were to reverse the process and start out with "No Fit" and XnView loaded it, it would be 100% instead the 51% I keep getting.
Ok, right. When "No Fit", i set zoom to 100%
ckit
Post by ckit »
This has been fixed in RC5 - retested and confirmed.
Locked
