RIOT — Radical Image Optimization Tool
All non-XnView related: softwares, formats, imaging, photography...
Moderators: XnTriq, xnview
Peter2
Re: RIOT — Radical Image Optimization Tool
Post by Peter2 »
Peter2 wrote:For the plugin, the download still contains version 0.5.2 from 2013.
Peter
The information can be found in the link from above ..
http://luci.criosweb.ro/riot/long-expec ... -released/
The plugin version is still under testing and a 0.6 version of the plugin will be released when testing will be completed. 0.5.2 is the latest usable version of the plugin.
XnView 2.50.2 German, Win 10
Moderator & Librarian
Peter2 wrote:The information can be found in the link from above ..
Thanks, Peter! I overlooked that too.
Peter2
Post by Peter2 »
Current version of the plugin is released:
v 0.6.0 / 27.12.2016
http://luci.criosweb.ro/riot/download/
Peter2 wrote:Current version of the plugin is released:
Thank you for keeping track of this, Peter (-:
Version 0.6.1 released
v0.6.1 (15.Oct.2018) wrote:+ added support for Gimp 2.10 in the plugin installer
* fixed a bug in batch mode where in certain conditions optimized files don’t get written
* fixed memory leak when opening the batch window, which also caused Access Violation in host applications if used as plugin
* fixed issue with saving of zoom factor
* fixed default batch window size not showing Settings button in certain situations
* fixed Compress to Size button not always enabled when needed
* minor UI fixes
– removed feature to toggle “Report file size changes” from batch settings. It is on by default
– removed menu item for Help Context. Docs will be moved to the website
v0.6.2 (07.May.2019) wrote:
  • fixed clipboard lock
  • fixed keep original date/time if in-place optimization
  • prevent delete of original if in-place optimization and “Delete original files” are used
  • fixed keep original file extension when saving files in batch
  • fixed keep original file extension when saving files from the main window
  • fixed file extension filter when using the Save As dialog for less common JPEG extensions
  • fixed render images after Auto resize dialog is discarded
  • fixed multi-monitor issue: restore position only if the saved position would be inside the visible area
  • fixed overriding settings in “Auto, Custom Format mode” did not switched the mode the Manual
  • fixed “Auto, Custom Format mode” blending transparency for JPEG format (white color usad now by default instead of black, but should use the last chosen color)
  • ! improved check for updates procedure. now enabled by default. does not create temporary files anymore
  • + added minimum compression setting to PNG (zlib level 1). This is useful for using with an external optimizer or reducing colors before final compression
  • + png compression settings “minimum” and “low” are always remembered upon program restart if save settings on exit is enabled.
Version 0.6.2 is here
https://www.riot-optimizer.com/riot-reaches-version-1-0-with-amazing-changes/ wrote:
[+] 64 bit version, allowing bigger images to be processed (>50 MP)
[!] improved compression with up to 30% for jpeg images
[+] decoding support for jpeg images using arithmetic coding
[+] improved PE security with DEP and ASLR
[!] the AVX2 instruction set for the 64bit version should provide better performance on larger images
[!] the 32 bit version is gonna be deprecated (probably the last 32 bit release)
[*] fixed display of optiized size in higher text dpi settings
[*] using less memory after the image is analyzed
[*] other minor fixes & tweaks
https://www.riot-optimizer.com/version-1-0-1-released/ wrote:[!] replaced AVX2 with SSE2 for better compatibility with older CPUs
https://www.riot-optimizer.com/64-bit-version-of-the-riot-plugin-officially-released/ wrote:The 64 bit version of the plugin is available for GIMP and XNViewMP.
Note that you need the 64bit version of the host applications too.
XNViewMP comes as 64bit and 32bit, so technically the 32bit version should work with the 32bit version of the plugin.
The installer should detect GIMP 2.10 and XNViewMP. If you used portable versions, you need to manually choose the Plugins/Addons folder.
The installer is now HiDPI aware, and the text will look crisp on such displays.
Note: IrfanView has discontinued support for RIOT. The IrfanView author insists on bundling RIOT and insists on certain size/structure of the plugin. If you want RIOT back you can write him to request to add back the support and not care about the size or structure of RIOT.
