v.0.30: After resize, wrong values in statusbar
Troken
Post by Troken »
When resizing an image, the old size is still shown in the status bar below the image. If you click in the menu, the new proper size is revealed.
Troken
Re: v.0.30: After resize, wrong values in statusbar
Post by Troken »
EDIT: The above post only applies when working with pixels. When working with percentage, the values are instantly right.
(But resize with percentage does not work properly, which is explained in http://newsgroup.xnview.com/viewtopic.php?f=62&t=21060)
Please check XnViewMP 0.31
Troken
Post by Troken »
Works like a charm. Fixed.
