XnView 1.80 Release Candidate 3 (Windows)
Moderators: XnTriq, xnview
Locked
Post by xnview » Thu May 26, 2005 1:17 pm
XnView v1.80 RC3 is available here : http://www.xnview.com/beta/XnView-RC3.zip
Currently only Phoenity skins are updated.
Download portals and websites must link to final versions of XnView only, and in no case link to any of the release candidates.
With the 1.80 version, you have now a folder WebTemplate for "HTML create". If someone can create better template for XnView (with CSS style), it would be great.
Known problems or issues not fixed:
* Scroll of picture in lite fullscreen (with infos)
* Dual monitor for slide/fullscreen
* Associations on Xp
Post by helmut » Thu May 26, 2005 1:29 pm
Thank you, Pierre, for fixing many, many bugs and issues.
ckit
Post by ckit » Thu May 26, 2005 1:33 pm
Thanks Pierre!
I love what you did with disabling PDF's in the preview pane :)
Windows 10 Pro x64 1909
XnViewMP and Classic and PhotoFiltre Studio X
Re: XnView 1.80 Release Candidate 3 (Windows)
Post by xnview » Thu May 26, 2005 4:53 pm
The cache feature is changed, so you must delete all files in cache folder.
ecsjjgg
Attention!!!!
Post by ecsjjgg » Thu May 26, 2005 6:51 pm
The download link you provided (http://www.xnview.com/beta/XnView-RC3.zip)does not work!!! Can you give me a mirror???
Re: Attention!!!!
Post by helmut » Thu May 26, 2005 7:09 pm
ecsjjgg wrote:The download link you provided (http://www.xnview.com/beta/XnView-RC3.zip)does not work!!! Can you give me a mirror???
Just tried, it does work. I doubt that there is a mirror for the release candidates. Could you please retry?
ecsjjgg
Post by ecsjjgg » Thu May 26, 2005 7:20 pm
Yes, it did work, but not when I was using FlashGet...
Remember last window position/size
Post by Guest » Sun May 29, 2005 12:57 pm
Remembers position but not size.
Locked
