Does XnView support 3GP and 3GPP formats ?
Post by Guest »
Re: Does XnView support 3GP and 3GPP formats ?
Anonymous wrote:Does XnView support 3GP and 3GPP formats ?
Which software use this format? Could you send me some samples?
BraVo567
Post by BraVo567 »
It is video, for mobile phones, for example http://kalitva.ru/_/3gp/kwn24.3gp
Dreamer
Post by Dreamer »
I'd like to have it too. Any plans Pierre? Cell phones are very popular now...
Documents ?
:arrow: Pierre
:) Hi Pierre !
- The format is unknown @ M$ today…
However, maybe could you get an information from this site. :wink: Good luck !
:mrgreen: Kind regards,
Dreamer wrote:I'd like to have it too. Any plans Pierre? Cell phones are very popular now...
Do you have other 3GP samples?
Dreamer
Post by Dreamer »
Yes, I can make as many as you need, but what exactly do you need? Short/long, in higher resolution...?
Edit: when I rename 3gp extension to avi or mpg, I can play it in xnview player, but there is no thumbnail. Probably it's a standard behavior, since I have codec for that filetype. XnView should be able to play it without big changes I think.
Yes, please, short movie in 2 resolution for example?
Dreamer
Post by Dreamer »
xnview wrote:Yes, please, short movie in 2 resolution for example?
Done, please let me know if you have received them, thanks.
yes thanks
B.Douille
Post by B.Douille »
This would be nice to support 3GP. Actually it's H264 and is supported by the QuickTime player.
Thanks
VuDu
Post by VuDu »
just rename it to *.mov and it'll work ;)
Ad decus et ad libertatem nati sumus
Aut haec teneamus aut cum dignitate moriamur
VuDu wrote:just rename it to *.mov and it'll work ;)
Unchecking the option "Recognize only by extension" in "Tools > Options > Browser > File List" might help and make renaming superfluous.
