Hello everyone,
This software is very good and I have been using on my pc for a long time. Thanks Pierre for this great job.
However I have installed it on my HTC HD2 and I also have a save problem to save a picture after adjustment. I have tried all recommandation in the forum with no sucess. Any new trick?
Problem to save after image adjustment
- Moderator
Re: Problem to save after image adjustment
What happens when saving the image on your HTC? Is there an error message?
Helmut, Pierre thanks to try to help me.
The message I have is exactly: " Problème pendant le sauvegarde du fichier!"
The size of the file is around 100K.
I have done several testing. And have found some tricks. At the begining the file format was not defined and when I have defined it nothing was changed and i also had some crashes of the program... So the settings was not saved...
Since I have set the file format for each utility tools and stop Xnview properly with the Quit option in the file menu. The settings are now saved and all functions seems to work fine and the program doesn't crash anymore. I hope that can help.
May be if file format are set during the installation this problem could be fixed.
Yes it is jpeg.
Could you send me it for testingscaloux wrote:Yes it is jpeg.
