RC3: Left-click scrolling & Folder Tree?
Locked
Criftus
Post by Criftus »
I'd love to be able to scroll around my images using the left-click-drag instead of the current method (right-click-dragging). I don't use the cropping features of XnView, and I zoom with the keyboard, so the left-click remains essentially useless during everyday use.
Also, with the XnView browser, the folder tree is set to act like a simplified explorer folder tree (one-click expands the sub-folders). Is there an option to turn that off? I'm used to double-clicking on folders when I'd like to view any sub-contents.
Cheers,
Criftus
Criftus@hotmail.com
Dreamer
Re: [Request?] Left-click scrolling & Folder Tree?
Post by Dreamer »
Criftus wrote:I'd love to be able to scroll around my images using the left-click-drag instead of the current method (right-click-dragging). I don't use the cropping features of XnView, and I zoom with the keyboard, so the left-click remains essentially useless during everyday use.
You mean "Swap LMB and RMB"?
Use LMB for move large image and RMB for make selection?
If so, I fully agree, I already requested this. It would be very useful, not only for former ACDSee users.
Criftus wrote:Also, with the XnView browser, the folder tree is set to act like a simplified explorer folder tree (one-click expands the sub-folders). Is there an option to turn that off? I'm used to double-clicking on folders when I'd like to view any sub-contents.
Already requested, don't reply here please.
Dreamer
Post by Dreamer »
Dreamer wrote:You mean "Swap LMB and RMB"?
Pierre, what you think?
Ok, i'll add configuration for that.
For to zoom in selection, must i use always LMB? because RMB open popup menu...
Dreamer
Post by Dreamer »
Great, thanks :D
xnview wrote:For to zoom in selection, must i use always LMB? because RMB open popup menu...
Yes, right.
And maybe "Make selection" with both buttons if "move" is not possible. Once "move" would be possible (image would be larger that screen), for "move" use LMB.
Locked
