Strange problem with "." symbol in Batch Rename:
When I select few files with number and "." symbol, "Create new name template when opening dialog" option is enabled, press F2, there are no characters on the right of "." symbol there.
E.g.:
Original filename (first) - "Number 01. Filename.jpg"
When I select few files and press F2, ther is:
Next to Name Template - "Number ##"
Below New Name - "Number 01.jpg"
When I double click on a file:
Next to Name Template - "Number ##. Filename.jpg" (OK)
Below New Name - "Number 01"
When I double click on a file again:
Below New Name - "Number 01. Filename.jpg" (OK)
When I click on Rename button then, files are renamed correctly.
So it works but I must click on a file twice first.
At the beginning I thought that problem is with all numbers at the start of the filename (e.g. "01 filename.jpg), therefore so long post, but problem is only with "." symbol in the filename.
[Fixed] RC2: Strange problem with . symbol in Batch Rename
Re: RC2: Strange problem with . symbol in Batch Rename
I'll fix itDreamer wrote:Strange problem with "." symbol in Batch Rename:
E.g.:
