RC2: Internal Video Player bug with Zoom
ckit
Post by ckit »
When playing a video in XnView using the internal player,
if you choose Zoom In or Zoom Out a black strip will appear to the right about the thickness of a scrollbar.
XnView 1.80 <x>
Dreamer
Post by Dreamer »
Zoom In and Zoom Out for videos doesn't work completely, it's a known bug. Only Numpad "/" works.
ckv
Post by ckv »
I would say SOLVED
Dreamer
Post by Dreamer »
ckit? (I can't confirm because I never had this problem.)
ckit
Post by ckit »
Yes, it's FIXED or at least known issue.
ckit wrote:Yes, it's FIXED or at least known issue.
Think we should keep this problem "Opened" as a reminder that Zoom in/out is still an issue.
ckit
Post by ckit »
You should make it a "Sticky" post so it's always at the top.
